Use this command to enable or disable the ability to change RADIUS (Remote Authentication Dial In User Service) server settings per WLAN (Wireless Local Area Network) Service. This command is available from the vnsmode:radius context.
enable | Enables changing RADIUS server settings per WLAN Service. |
disable | Disables changing RADIUS server settings per WLAN Service. |
This example disables changing RADIUS server settings per WLAN Service:
EWC.extremenetworks.com:vnsmode:radius# strict disable
