Use the rateprf-in command to associate an already existing rate profile as an ingress rate profile for a CoS (Class of Service). The rateprf-in command is accessible from the cos:<named-cos> context.
profile | Specifies the ingress rate profile to configure for this wlans:default-cos context. |
none | Specifies that the ingress rate profile is used for this wlans:default-cos context. |
Refer to rateprofile for rate profile configuration information.
The following example configures the default-policy with the DocRateIn ingress rate profile:
EWC.extremenetworks.com:cos:my-cos# rateprf-in DocRateIn EWC.extremenetworks.com:cos:my-cos# apply EWC.extremenetworks.com:cos:my-cos# show Assigned topology: guestPortal Ingress rate profile: DocRateIn Egress rate profile: Unlimited Enable AP filtering: disable Synchronize: enable EWC.extremenetworks.com:cos:my-cos#
