Use the lldp command to enable the broadcast of the LLDP protocol by a Wireless AP. Use the no form of the command to disable LLDP. The lldp command is accessible from the ap:<serial> and all ap:defaults contexts of the CLI.
Announcement Interval | Specifies the scheduled frequency, measured in seconds, in which the Wireless AP advertises its information by sending a new LLDP packet. Range is 5 to 32768. |
Announcement Delay | Specifies the delay, measured in seconds, between successive LLDP frame transmissions that is initiated by a value/status change in the LLDP local systems MIB. Range is 1 to 1/4 x Announcement Interval value. |
The following example enables LLDP for the default Wireless AP configuration with an announcement interval of 30 seconds, and an announcement delay of 2:
EWC.extremenetworks.com:ap:defaults:3935FCC# lldp 30 2
If SNMP (Simple Network Management Protocol) is enabled to publish on the Wireless Appliance and you enable LLDP, the following message is displayed:
WARNING: SNMP is set to publish. How Do you wish to continue? (C) Cancel (P) Proceed (O) Disable SNMP publishing and proceed
Type one of the following:
