Use the nasip command to configure an NAS IP address for this site. The nasip command is accessible from the site:<named-site> context. Use config exit to exit config mode.
A.B.C.D | Specifies an IP address for this <named-site>. |
vnsip | Specifies that the VNS (Virtual Networks Service) IP address is used as the IP address for this <named-site>. |
The CLI <named-site> context must be in config mode for a RADIUS (Remote Authentication Dial In User Service) server to execute the nasip command. Use the config radius name command to enter config mode.
The following example configures a VNS IP address as the IP address for site1:
EWC.extremenetworks.com:site:site1# nasip vnsip
