Use the delete command to delete a bandwidth rate control profile. The delete command is accessible from the vnsmode:rateprofile context of the CLI.
If the rate control profile that you are attempting to delete is being used by any other VNS (Virtual Networks Service), the system returns the following message: You can not delete this profile because it is used by other VNS.
profile_name | Specifies the name of the bandwidth rate control profile to delete. |
The following example deletes the lowspeed profile:
EWC.extremenetworks.com:vnsmode:rateprofile# delete lowspeed
