Use the engine-id command to configure the SNMPv3 engine ID for the Wireless Appliance running the SNMP (Simple Network Management Protocol) agent.
string | Specifies the SNMPv3 engine ID for the Wireless Appliance running the SNMP agent. The string must be from 5 to 32 characters in length when auto-gen is not selected, and from 1 to 27 characters when auto-gen is selected. |
auto-gen | Automatically generates the SNMPv3 engine ID from the manually entered string. |
The following example specifies the SNMPv3 engine ID of the SNMP agent. Note that resetting the engine-id will reset all users:
EWC.extremenetworks.com:snmp# engine-id aaaaaaa All users will be reset. (yes/no):no Warning : Operation to update engine ID cancelled.
