Use the route command to add routing information. Use the no forms of the command to disable the information.
Use show routes to display the routing table. For more information, see show routes.
IP Address | Specifies the destination IP address |
netmask | Specifies the subnet mask |
/netmask | Specifies the subnet mask in CIDR format |
gateway | Specifies the gateway |
float | Does not override OSPF (Open Shortest Path First) learned route |
nofloat | Overrides OSPF learned route |
routeId | Specifies index number of route on the routing table |
The following example adds an IP address to the routing table, specifying the netmask in CIDR format and disallowing OSPF overrides:
EWC.extremenetworks.com:ip# route 1.1.2.1/24 10.7.0.3 nofloat
The following example adds an IP address to the routing table, specifying the netmask as an IP address and allowing OSPF overrides:
EWC.extremenetworks.com:ip# route 1.1.2.1 255.255.255.0 10.7.0.3 float
The following example configures the default route:
EWC.extremenetworks.com:ip# route default 10.7.0.3
The following example removes an IP address from the routing table:
EWC.extremenetworks.com:ip# no route 1.1.2.1
The following example removes the default route from the routing table:
EWC.extremenetworks.com:ip# no route default
The following example removes an IP address from the routing table by its index number:
EWC.extremenetworks.com:ip# no route 12
