Use the name command to change the name of a CoS (Class of Service). The name command is accessible from within the cos:<named-cos> context.
new-name | Specifies the new name for this <named-cos>. |
You must enter the apply command before exiting the cos:<named-cos> context for the CoS name change to take affect. The CLI prompt does not change until you exit and re-enter the cos:<named-cos> context.
The following example:
EWC.extremenetworks.com:cos# your-cos EWC.extremenetworks.com:cos:your-cos# name my-cos EWC.extremenetworks.com:cos:your-cos# apply EWC.extremenetworks.com:cos:your-cos# show Name: my-cos Use Legacy Priority Override defined in the WLAN Service: disable 802.1p Priority: none ToS/DSCP Marking: Mask: Inbound Rate Limit: Outbound Rate Limit: Transmit Queue: none Synchronize: enable EWC.extremenetworks.com:cos:your-cos# exit EWC.extremenetworks.com:cos# my-cos EWC.extremenetworks.com:cos:my-cos#
