Use the following procedure to view the online, offline and root certificates in the local store.
 - Click Certificate.
 - Click the Certificate Store tab.
Certificate Store field descriptions
Use the data in the following table to use the Certificate Store tab.
 Name  |
 Description  |
 CommonName  |
 Specifies the Common Name of the Certificate Authority issuing the Digital Certificate.  |
 Type  |
 Specifies the certificate type.  |
 VersionNumber  |
 Specifies the version number of the certificate for the subject as issued by the Certificate Authority.  |
 SerialNumber  |
 Specifies the serial number of the certificate for the subject as issued by the Certificate Authority.  |
 IssuerName  |
 Specifies the name of the issuer of the certificate for the subject as issued by the Certificate Authority.  |
 ValidStartPeriod  |
 Specifies the start date of the validation period of the certificate for the subject as issued by the Certificate Authority.  |
 ValidEndPeriod  |
 Specifies the last date of the validation period of the certificate for the subject as issued by the Certificate Authority.  |
 CertificateSignatureAlgorithm  |
 Specifies the algorithm used for the signature of the issuer on the certificate for the subject as issued by the Certificate Authority.  |
 CertificateSignature  |
 Specifies the signature of the issuer on the certificate for the subject as issued by the Certificate Authority.  |
 Subject  |
 Specifies the details of the subject on its certificate as issued by Certificate Authority.  |
 SubjectPublicKeyAlgorithm  |
 Specifies the algorithm used to generate the subject's public key for the certificate issued by the Certificate Authority.  |
 SubjectPublicKey  |
 Specifies the public key of the subject used for Certificate Signing Request.  |
 HasBasicConstraint  |
 Specifies whether certificate contains basic certificate constraint.  |
 HasKeyUsage  |
 Specifies whether certificate contains basic key usage constraint.  |
 IsCa  |
 Specifies if the certificate is a CA certificate or not.  |
 KeyUsage  |
 Specifies the purpose of the key used in the certificate. It is
represented in the form of bits as follows:
 Status  |
 Specifies the status of the certificate.  |
 Installed  |
 Specifies whether the certificate is installed or not.  |
 CdpUrl  |
 Specifies the CDP URL present in the Digital Certificate Extensions field.  |
 OscpUrl  |
 Specifies the OCSP URL present in the Digital Certificate AIA field.  |
 ExtendedKeyUsage  |
 Indicates the purpose for which the key is used in addition to or in place of the basic purposes indicated in the key-usage field of the certificate.  |
 CaFileName  |
 Specifies the certificate file obtained offline from the Root Certificate Authority.  |
