Use the data in the following table to use the Power Consumption tab.
 Name  |
 Description  |
                                 Index  |
                                 Displays an index value that identifies the component.  |
                                 PowerStatus  |
                                 Displays the power status: on or off.  |
                                 ConsumedPower  |
                                 Displays the actual consumed power for the slot. This value is 0 if the power status is off.  |
                                 SlotDescription  |
                                 Displays the slot number.  |
                                 CardDescription  |
                                 Identifies the type of module in the slot.  |
