Use the following procedure to display information about the VNID forwarding database (FDB).
 - Select VTEP.
 - Select the Vnid FDB tab.
Vnid FDB field descriptions
Use the data in the following table to use the Vnid FDB tab.
 Name  |
 Description  |
 Vnid  |
 Displays the VNID IDs of the VXLAN tunnel endpoints.  |
 Address  |
 Displays all the learned MAC addresses in the forwarding database of the selected VNID.  |
 Status  |
 Displays whether or not the MAC address was learned.  |
 InterfaceIndex  |
 Displays the interface index name for the VNID.  |
 Type  |
 Displays whether the VNID is local or remote.  |
