View IPv6 VRRP Statistics
View IPv6 VRRP statistics to monitor network performance.
 - Select VRRP.
 - Select the Stats tab.
Stats Field Descriptions
Use the data in the following table to use the Stats tab.
 Name  |
 Description  |
 InetAddrType  |
 Shows the type of IP address (IPv4 or IPv6).  |
 ChecksumErrors  |
 Shows the number of VRRP packets received with an invalid VRRP checksum value.  |
 VersionErrors  |
 Shows the number of VRRP packets received with an unknown or unsupported version number.  |
 VrIdErrors  |
 Shows the number of VRRP packets received with an invalid VrID for this virtual router.  |
