Configure the counter sampling interval values at port level to determine how often the sFlow agent polls and exports counters for a configured interface.
You must globally enable sFlow.
Verify all slots use the default polling-interval configuration.
Switch:1(config-if)#sflow counter-interval 525
Switch:1(config-if)#show sflow interface 1/1-1/10
                         sFlow Port Configuration Info
Port   Packet-Sample-Rate  Max-Header-Size Counter-interval  Collector-list
                                           (in secs)
1/1    0                   128             525               1,2
1/2    0                   128             525               1,2
1/3    0                   128             525               1,2
1/4    0                   128             525               1,2
1/5    0                   128             525               1,2
1/6    0                   128             525               1,2
1/7    0                   128             525               1,2
1/8    0                   128             525               1,2
1/9    0                   128             525               1,2
1/10   0                   128             525               1,2
All 10 out of 10 Total Num of sflow port entries displayed
Use the data in the following table to use the sflow counter-interval and show sflow interface commands.
 Variable  |
 Value  |
 <1–3600>  |
 Specifies the polling interval for a slot. Default value is 0 (disabled).  |
 {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
