Complete the following tasks to configure DHCP Server using EDM. Complete only the tasks that apply to your deployment.
Before You Begin
| Step | Procedure | Description |
| 1 | Configure DHCP Server Global Settings | Configure global settings for the DHCP Server. |
| 2 | Configure Global DNS | Assign default DNS servers to the DHCP Server. |
| 3 | Configure Global NTP | Assign default NTP servers to the DHCP Server. |
| 4 | Configure Custom Option Definitions | Configure this tab to define Custom Options that let you assign non-standard DHCP parameters. |
| 5 | Configure Custom Option Data | If you've defined Custom Options, assign data values to the DHCP Server. |
| 6 | Configure DHCP Subnet | Configure a DHCP subnet and assign an IP address pool to the subnet. |
| 7 | Configure Subnet Routers | Assign IP addresses to subnet routers. |
| 8 | Configure Subnet DNS | Assign DNS servers for this subnet. |
| 9 | Configure Subnet NTP Servers | Assign NTP servers for this subnet. |
| 10 | Configure Subnet Custom Option Data | If you've defined DHCP Custom Options, configure per-subnet data values for those options. |
| 11 | Configure Hosts | Configure the Hosts tab only if you have hosts for whom you want to reserve details, such as a specific IP address. |
| 12 | Enable DHCP Server | After you've configured DHCP Server, enable the server on the switch. |
| 13 | For High Availability, repeat the DHCP Server configuration on the peer switch |
What to do Next
