Configure Static Hosts
Use the variable definitions in the following table to configure static host reservations within a DHCP subnet.
| Variable | Definition |
| host <0x00:0x00:0x00:0x00:0x00:0x00> |
                                 Specifies the MAC address for the host.  |
| ip-address {A.B.C.D} |
                                 Assigns an IPv4 address to the host. The IP address must be taken from the address pool that is configured for the DHCP subnet where the host resides.  |
| hostname WORD<0-64> |
                                 Specifies a hostname for the host.  |
| tftp server-ip {A.B.C.D} |
                                 Specifies the IP address of the TFTP server that you want to assign to the host. You must assign the TFTP IP address before you can assign a server name or boot file name. Note: For this host, these TFTP settings override conflicting TFTP
                                    settings from the subnet or DHCP Server.
| tftp server-name WORD<0-64 |
                                 Specifies the server name of the TFTP server that you want the host to use.  |
| tftp boot-file-name WORD<0-128> |
                                 Specifies the boot image filename that you want the host to use.  |
