The switch configures the following protocols, by default:
Time Service
Terminal Access Controller Access Control System (TACACS) Service
Domain Name System (DNS)
Trivial file transfer protocol (TFTP)
Network Basic Input/Output System (NetBIOS) NameSrv
NetBIOS DataSrv
You can use these protocols to create forwarding entries and lists but you cannot delete them; you can add or remove other protocols to the list of protocols.
Protocols field descriptions
Use the data in the following table to use the Protocols tab.
 Name  |
 Description  |
 PortNumber  |
 Defines the UDP port (1 to 65535).  |
 Name  |
 Specifies an administratively assigned name for this list (0 to 15 characters).  |
