Display the configuration to view current or changed settings for the boot parameters.
Show the current boot configuration. (If you omit verbose, the system only displays the values that you changed from their default value.):
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1#(config)#show boot config running-config # #Mon Feb 13 13:32:58 2017 EST # boot config flags debug-config file boot config flags debugmode boot config flags ftpd no boot config flags spbm-config-mode boot config flags sshd boot config flags telnetd boot config flags tftpd no boot config flags verify-config boot config choice primary backup-config-file "/intflash/config.cfg" #boot config sio console baud 115200
The following table defines parameters for the show boot config command.
 Variable  |
 Value  |
 choice  |
 Shows the current boot configuration choices.  |
 flags  |
 Shows the current flag settings.  |
 general  |
 Shows system information.  |
 host  |
 Shows the current host configuration.  |
                             master  |
 Shows the master information.  |
 running-config [verbose]  |
 Shows the current boot configuration. If you use verbose, the system displays all possible information. If you omit verbose, the system displays only the values that you changed from their default value.  |
 sio  |
 Specifies the current configuration of the serial ports.  |
