Configure Custom Option Definitions
Use this procedure to configure the DHCP Server Custom Option Definitions tab
in EDM.
Custom Option Definitions Field Descriptions
Use the data in the following table to configure the Custom Option Definitions tab for DHCP Server.
| Name | Description |
| ID | Specifies the DHCP code of the option to which you want to assign this data. Enter an integer in the unassigned range from 224 to 254. |
| Type |
Assigns a data type to this Custom Option. All data values that use this custom option must follow the data type that you assign. Select one of three options:
| Name | Assigns a readable text label that identifies the custom option. |
