Simplified Virtual-IST (vIST) is for conventional switch clustering deployments that use SMLT and not SPB. The Simplified vIST feature provides a single CLI command to enable the virtual IST for SMLT deployments.
For Simplified vIST deployment, if a VLAN is part of an SMLT it must be configured on both of the IST peers.
Important
Important
Do not change the system MTU to less than the default value of 1950 bytes. The system MTU must be 1950 or jumbo because of a header size increase.
For configuration information, see Configure Simplified vIST in SMLT Topologies or Configuring Simplified vIST in SMLT topologies.
For information about how to configure Simplified vIST with multicast, see Enabling multicast on the switch.
