Configure ELAN Endpoints
Use the following procedure to configure information associated with ELAN end points.
- Select VTEP.
- Select the Elan End Points tab.
- In Vnid, specify the VNID associated with this ELAN.
- In Cvid, specify the customer VLAN ID.
- In IfIndex, specify the interface index for this ELAN endpoint.
- Select Apply.
Elan End Points field descriptions
Use the data in the following table to use the Elan End Points tab.
Name |
Description |
Vnid |
Specifies a value that uniquely identifies the VNID of this ELAN tunnel end point. |
Cvid |
Specifies a value that uniquely identifies the customer VLAN ID of this ELAN endpoint. The switch reserves the following VLAN IDs:
IfIndex |
Specifies the interface index for the MLT or port for this ELAN endpoint. |
Isid |
Specifies the I-SID associated with this VNID. |
