Enable SLPP by port to detect a loop and automatically stop it.
Important
To provide protection against broadcast and multicast storms, as a best practice, enable Rate Limiting for broadcast traffic and multicast traffic.
Switch(config-if)# slpp port 1/1 packet-rx-threshold 5
Use the data in the following table to use the slpp port command.
                             Variable  |
                             Value  |
                             <1-500>  |
                             Specifies the SLPP reception threshold on the ports, expressed as an integer. The packet reception threshold specifies how many SLPP packets the port receives before it is administratively disabled. To set this option to the default value, use the default operator with the command. The default value is 1. Note:
                        As a best practice, configure the rx-threshold above 50 slpp packets only on lightly loaded switches. If you configure the rx-threshold to a value greater than 50 on a heavily loaded switch and a loop occurs, the system can experience high CPU utilization.  |
                             {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
                             Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
Job aid
The following table provides the SLPP values.
 Enable SLPP  |
 Setting  |
 Access SMLT  |
 Yes  |
 Core SMLT  |
 No  |
 Primary switch  |
 Packet Rx threshold  |
 5  |
 Transmission interval  |
 500 milliseconds (ms) (default)  |
 Secondary switch  |
 50  |
 500 ms (default)  |
