Use the following procedure to enable IPv6 ECMP globally or on a specific VRF. IPv6 ECMP is disabled by default.
Use the data in the following table to use the ipv6 ecmp command.
Variable |
Value |
enable |
Enables IPv6 ECMP globally. Note:
