View tunnel interfaces to verify the current configuration and operational status of IPv6 tunnels.
Switch:1#show ipv6 tunnel detail
                          Tunnel Interface Information
ID         LOCAL ADDRESS   REMOTE ADDRESS  OPER STATUS TYPE
2          211.1.55.2      44.1.55.1       active      manual
1          211.1.55.2      44.1.55.43      active      manual
210        211.1.60.2      47.1.60.1       active      manual
3 out of 3 Total number of entries displayed.
                              Address Information
IPV6 ADDRESS/PREFIX LENGTH                   TYPE    ORIGIN    STATUS
43:210:0:0:0:0:0:2/64                        UNICAST MANUAL    PREFERRED
fe80:0:0:0:0:0:d301:3702/64                  UNICAST LINKLAYER PREFERRED
44:211:0:0:0:0:0:2/64                        UNICAST MANUAL    PREFERRED
Variable definitions
Use the data in the following table to use the show ipv6 tunnel command.
Variable  | Value  |
<1–2000>  | Shows information for a specific tunnel ID.  |
detail  | Shows detailed address information for the tunnel.  |
local {A.B.C.D}  | Shows information for a specific local address (the local endpoint of the tunnel).  |
remote {A.B.C.D}  | Shows information for a specific remote address (the remote endpoint of the tunnel).  |
