Display SNMP statistics to monitor the number of specific error messages, such as the number of messages that were delivered to SNMP but were not allowed.
 - Click General.
 - Click the SNMP tab.
SNMP Field Descriptions
Use the data in the following table to display SNMP statistics.
 Name  |
 Description  |
 OutTooBigs  |
 Shows the number of SNMP PDUs that the SNMP protocol entity generated and for which the value of the error-status field is tooBig.  |
 OutNoSuchNames  |
 Shows the number of SNMP PDUs that the SNMP protocol entity generated and for which the value of the error-status is noSuchName.  |
 OutBadValues  |
 Shows the number of SNMP PDUs that SNMP protocol entity generated and for which the value of the error-status field is badValue.  |
 OutGenErrors  |
 Shows the number of SNMP PDUs that the SNMP protocol entity generated and for which the value of the error-status field is genErr.  |
 InBadVersions  |
 Shows the number of SNMP messages that were delivered to the SNMP protocol entity and were for an unsupported SNMP version.  |
 InBadCommunityNames  |
 Shows the number of SNMP messages delivered to the SNMP protocol entity that used an SNMP community name not known to the entity.  |
 InBadCommunityUsers  |
 Shows the number of SNMP messages delivered to the SNMP protocol entity that represented an SNMP operation not allowed by the SNMP community named in the message.  |
 InASNParseErrs  |
 Shows the number of ASN.1 or BER errors encountered by the SNMP protocol entity when decoding received SNMP messages.  |
 InTooBigs  |
 Shows the number of SNMP PDUs that were delivered to the SNMP protocol entity and for which the value of the error-status field is tooBig.  |
 InNoSuchNames  |
 Shows the number of SNMP PDUs that were delivered to the SNMP protocol entity and for which the value of the error-status field is noSuchName.  |
 InBadValues  |
 Shows the number of SNMP PDUs that were delivered to the SNMP protocol entity and for which the value of the error-status field is badValue.  |
 InReadOnlys  |
 Shows the number of valid SNMP PDUs delivered to the SNMP protocol entity and for which the value of the error-status field is "read-only". It is a protocol error to generate an SNMP PDU that contains the value "read-only" in the error-status field; this object is provided as a means of detecting incorrect implementations of the SNMP.  |
 InGenErrors  |
 Shows the number of SNMP PDUs delivered to the SNMP protocol entity and for which the value of the error-status field is "genErr."  |
