Use the Routes tab to view and manage the contents of the system routing table. You can also delete a dynamically learned route using this table. Exercise caution if you delete entries from the route table.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
To delete a static route, use the StaticRoute tab.
- In the navigation tree, expand .
 - Select IP.
 - Select the Routes tab.
 - To delete a route, select the route, and then select Delete.
Routes field descriptions
Use the data in the following table to use the Routes tab.
 Name  |
 Description  |
 Dest  |
 Specifies the destination IP network of this route. An entry with a value of 0.0.0.0 is a default route. The system can display multiple routes to a single destination in the table, but access to multiple entries depends on the table access mechanisms defined by the network management protocol in use.  |
 Mask  |
 Indicates the network mask to logically add with the destination address before comparison to the destination IP network.  |
 NextHop  |
 Specifies the IP address of the next hop of this route.  |
 AltSequence  |
 Indicates the alternative route sequence. The value of 0 denotes the best route.  |
 NextHopId  |
 Specifies the identifier of the next-hop, hostname or MAC address.  |
 HopOrMetric  |
 Specifies the primary routing metric for this route. The semantics of this metric are specific to various routing protocols.  |
 Interface  |
 Specifies the router interface for this route.
 Proto  |
 Specifies the routing mechanism through which this route was learned:
 Age  |
 Specifies the number of seconds since this route was last updated or otherwise determined correct.  |
 PathType  |
 Indicates the route type, which is a combination of direct, indirect, best, alternative, and ECMP paths.
 Pref  |
 Specifies the preference.  |
 NextHopVrfId  |
 Specifies the VRF ID of the next-hop address.  |
