Configure Custom Option Data
Use this procedure to configure the DHCP Server Custom Option
            Data tab for an existing custom option.
- In the navigation pane, select .
 - Select the DHCP Custom Option Data tab.
 - In the ID field, enter the DHCP code that is defined for the option.
 - In the Value field, enter the data value that you want to assign to the option.
 - Select Insert.
 - Repeat these steps if you want to add data values for additional custom options.
Custom Option Data Field Descriptions
Use the data in the following table to configure the Custom Option Data tab for DHCP Server.
| Name | Description |
| ID | Specifies the DHCP code that identifies this Custom Option. Must be an integer in the range from 224 to 254. |
| Value | Assigns a data value to this Custom Option. The value must use the data type format that is specified in the Custom Option definition. |
