Create a new entry in the MIB View table.
You cannot modify SNMP settings with the default Layer 2 MIB view. However, you can modify SNMP settings with a new MIB view created with Layer 2 permissions.
 - Click VACM Table.
 - In the VACM Table tab, click the MIB View tab.
 - Click Insert.
 - In the ViewName box, type a view name.
 - In the Subtree box, type a subtree.
 - In the Mask box, type a mask.
 - From the Type options, select whether access to the MIB object is granted.
 - Click Insert.
MIB View field descriptions
Use the data in the following table to use the MIB View tab.
 Name  |
 Description  |
 ViewName  |
 Creates a new entry with this group name. The range is 1–32 characters.  |
 Subtree  |
 Specifies a valid object identifier that defines the set of MIB objects accessible by this SNMP entity, for example, 1.3.6.1.1.5.  |
 Mask (optional)  |
 Specifies a bit mask with vacmViewTreeFamilySubtree to determine whether an OID falls under a view subtree.  |
 Type  |
 Determines whether access to a MIB object is granted (included) or denied (excluded). The default is included.  |
