Perform this procedure to view and edit RSMLT peer information.
 - Select RSMLT.
 - Select the Peer tab.
Peer field descriptions
The following table defines parameters for the Peer tab.
 Name  |
 Description  |
 IfIndex  |
 IP interface identification.  |
 VlanId  |
 Specifies the VLAN ID of the chosen VLAN.  |
 IpAddr  |
 Specifies the IP address on the RSMLT VLAN.  |
 MacAddr  |
 Specifies the MAC address of the selected VLAN.  |
 Enable  |
 Displays the RSMLT operating status as enabled or disabled.  |
 OperStatus  |
 Displays the RSMLT operating status as either up or down. The default is down.  |
 HoldDownTimer  |
 Defines how long the recovering/restarting system remains in a non-Layer 3 forwarding mode for the peer router MAC address. The range of this value is from 0 to 3600 seconds. The default is 0.  |
 HoldUpTimer  |
 Defines how long the RSMLT system maintains forwarding for its peer. The value is a range from 0 to 3600 seconds or 9999. 9999 means infinity. The default is 0.  |
 HoldDownTimeRemaining  |
 Displays the time remaining of the HoldDownTimer. The default is 0.  |
 HoldUpTimeRemaining  |
 Displays the time remaining of the HoldUpTimer. The default is 0.  |
 SmltId  |
 Specifies the ID range for the Split MultiLink Trunk. A valid range is 1 to 32.  |
 VrfId  |
 Identifies the VRF.  |
 VrfName  |
 Indicates the VRF name.  |
