Configure a platform VLAN and associate the Guest I-SID. 0 indicates that Guest I-SID is not enabled for this port.
Use this procedure to configure the Guest I-SID.
Configure the Guest I-SID.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitEthernet 1/10 Switch:1(config-if)#eapol guest-isid 1000
The following table defines parameters for the eapol guest-isid command.
                             Variable  |
                             Value  |
                             <0-16000000>  |
                             Specifies the Guest I-SID value. 0 indicates that Guest I-SID is not enabled for this port.  |
