This VSA configures port and VLAN based attributes.
Value: 252
Type: String
Vendor: Extreme
Extreme Vendor ID is 1916
The following features can be configured using Extreme-Dynamic-Config RADIUS VSA:
VLAN-based features:
DHCP Snooping
IGMP Snooping
Port-based features:
Custom Auto-Negotiation Advertisements (CANA)
Bridge Protocol Data Unit (BPDU) Guard
IP Source Guard (IPSG)
Port bounce
Reauthentication
Simple Loop Prevention Protocol (SLPP) Guard
Traffic Control (Wake on LAN - WoL)
If you use the Extreme-Dynamic-Config RADIUS VSA, then Dynamic ARP Inspection and DHCP Snooping are only enabled on the default VLAN if IPSG is present in the RADIUS attributes.
AN-ADVERTISMENTS:100Half or AN-ADVERTISMENTS:100H settings configure CANA speed and duplex to the following supported values:
10Half
100Full
100Half
100Full
1000Full
This attribute enables BPDU Guard on the port where the client resides.
This attribute enables DAI on the VLAN received from the RADIUS server. For a Flex-UNI port, DAI is enabled on the platform VLAN associated with the I-SID received from the RADIUS server.
DAI is also enabled on the default VLAN of the port to prepare for IPSG, which requires DAI and DHCP Snooping enabled on all VLANs. If the RADIUS server does not return a VLAN of I-SID, DAI is enabled on the default VLAN. For Flex-UNI ports, DAI is enabled on the platform VLAN associated with the untagged I-SID.
If you use the Extreme-Dynamic-Config RADIUS VSA, then DAI is only enabled on the default VLAN if IPSG is present in the RADIUS attributes.
This attribute enables DHCP Snooping on the VLAN received from the RADIUS server. For a Flex-UNI port, DHCP Snooping is enabled on the platform VLAN associated with the I-SID received from the RADIUS server.
DHCP Snooping is also enabled on the default VLAN of that port to prepare for IPSG, which requires DAI and DHCP Snooping enabled on all VLANs. If the RADIUS server does not return a VLAN of I-SID, DHCP Snooping is enabled on the default VLAN. For Flex-UNI ports, DHCP Snooping is enabled for the platform VLAN associated with the untagged I-SID.
If you use the Extreme-Dynamic-Config RADIUS VSA, then DHCP Snooping is only enabled on the default VLAN if IPSG is present in the RADIUS attributes.
This attribute enables IGMP Snooping on the VLAN received from the RADIUS server. For a Flex-UNI port, IGMP Snooping is enabled on the platform VLAN associated with the I-SID received from the RADIUS server.
This attribute enables IPSG on the port where the client resides.
In order to apply IPSG, DHCP Snooping and DAI must be configured on the RADIUS server. DHCP Snooping and DAI must be enabled on all VLANs.
The following is an example of a log message that displays if a setting is not configured correctly:
GlobalRouter EAP WARNING Cannot apply Radius IP Source Guard attribute on port 1/15 without DHCP Snooping and DAI attributes.This attribute runs a port bounce on an EAP port including Power over Ethernet (PoE), if capable. Current EAP sessions are preserved during the port bounce process.
Use this attribute for on-demand re-authentication, for example, to use a power cycle to trigger a port bounce for a PC behind a phone, which is being rebooted, as in the following use cases:
To ensure a PC behind a phone acquires an IP address from the VLAN or I-SID assigned by the RADIUS server, the PC triggers a new DHCP negotiation if it receives the port-bounce attribute in the RADIUS-Accept packet.
To force a client to renew its DHCP IP address by using a RADIUS dynamic Change-of-Authorization (CoA) or Disconnect request.
CLI and EDM output that displays the interface state indicates if a port is down because of a RADIUS VSA port bounce.
This attribute enables EAPOL reauthentication on a port either manually using CLI or dynamically through RADIUS. The origin identifies how reauthentication was configured, either CONFIG or RADIUS.
This attribute enables SLPP Guard on the port where the client resides.
This attribute enables EAP traffic-control (Wake On LAN) on the port where the client resides.
| Session | REAUTH status | Cause |
| EAP Session | Without REAUTH VSA | On MAC ageout. Note: Session timeouts
if the client is not connected.
| With REAUTH VSA | On periodically timer and MAC ageout. | |
| NEAP Session | Without REAUTH VSA | On MAC Ageout. |
| With REAUTH VSA | Useful for silent devices, session stays active despite MAC
ageout. Session is removed only by manual intervention or RADIUS
reject/timeout. Note: The same command
activates both EAP and NEAP reauthentication. If
reauthentication is needed for EAP, NEAP reauthentication for
silent devices is automatically activated.
| Command | Level | Processing | Configuration | Prerequisites |
| Session-timeout | per session basis. |
Changes the reauth interval for a particular session. |
none. |
Enable port level reauthentication. |
| VSA (REAUTH:300 or REAUTH) | per port basis. |
Changes the port configuration. |
Enable reauthentication and configure interval. |
none. |
The following table shows the behavior for Dynamic Host Configuration Protocol Snooping (DHCP Snooping) and Dynamic ARP Inspection (DAI) Vendor Specific Attributes (VSA) for each authentication scenario, depending on Extensible Authentication Protocol (EAP) Operational mode, Flex-UNI mode, and IP Source Guard (IPSG) VSA or RADIUS VLAN/ISID.
EAP Operational Mode |
IPSG VSA received |
Flexi-UNI |
RADIUS VLAN/I-SID |
DHCPSNOOP and DAI VSA received |
Mutiple Host Single Authentication (MHSA) |
Yes | Yes | Yes |
DHCP, DAI, and IPSG enabled on all associated Platform VLANs. |
| MHSA | Yes | Yes | No |
| MHSA | Yes | No | Yes |
| MHSA | Yes | No | No |
| MHSA | No | Yes | Yes |
DHCP and DAI enabled on Platform VLAN associated with RADIUS I-SIDs. |
| MHSA | No | Yes | No |
DHCP and DAI enabled on all static Platform VLANs. |
| MHSA | No | No | Yes |
DHCP and DAI enabled on received RADIUS VLAN. |
| MHSA | No | No | No |
DHCP and DAI enabled on default VLAN. |
Mutiple Host Multiple VLAN (MHMV) |
Yes | Yes | Yes |
DHCP, DAI, and IPSG enabled on Platform VLAN associated with RADIUS I-SID and Platform VLAN associated with untagged I-SID. |
| MHMV | Yes | Yes | No |
DHCP, DAI, and IPSG enabled on Platform VLAN associated with untagged I-SID. |
| MHMV | Yes | No | Yes |
DHCP, DAI, and IPSG enabled on RADIUS VLAN and default VLAN. |
| MHMV | Yes | No | No |
DHCP, DAI, and IPSG enabled on default VLAN. |
| MHMV | No | Yes | Yes |
DHCP and DAI enabled on Platform VLAN associated with RADIUS I-SID. |
| MHMV | No | Yes | No |
DHCP and DAI enabled on Platform VLAN associated with untagged I-SID. |
| MHMV | No | No | Yes |
| MHMV | No | No | No |
Note:
If no RADIUS VLAN or Platform VLAN is associated with RADIUS I-SID, DHCP Snooping and DAI are enabled on the default VLAN or Platform VLAN associated with static untagged I-SID. |
