View application host statistics to see traffic statistics by application protocol for each host.
Switch:1# show rmon application-host-stats ?
  WORD<1-64>  Select one of these application protocols
              {TCP|UDP|FTP|TELNET|HTTP|RLOGIN|SSH|TFTP|SNMP|HTTPS}
Switch:1# show rmon application-host-stats FTP
                          Rmon Application Host Stats
HOSTADDR         INPKT      OUTPKT     INOCT      OUTOCT     CREATETIME
192.0.2.10        0          0          0          0          10/09/15 17:29:54
Protocol support can vary across platforms.
The following table defines parameters for the show rmon application-host-stats command.
| Variable | Value |
                             WORD<1–64>  |
                             Specifies one of the following application protocols: TCP, UDP, FTP, TELNET, HTTP, rlogin, SSH, TFTP, SNMP, HTTPS. Note:
                        RMON2 can count application packets received on a platform, even if the application is not enabled or supported, before dropping them.  |
