Edit the IPv6 PIM parameters for an interface to customize the IPv6 PIM configuration.
- In the navigation pane, expand the following folders: .
 - Click IPv6 PIM.
 - Click the Interfaces tab.
 - Edit the fields by double-clicking on them, and then select or type the new value.
 - Click Apply.
Interfaces field descriptions
Use the data in the following table to use the Interfaces tab.
 Name  |
 Description  |
 IfIndex  |
 Shows the interface Index. This variable is a read-only field.  |
 Address  |
 Shows the IPv6 address of the PIM interface. This variable is a read-only field.  |
 NetMask  |
 Shows the network mask for the IPv6 address of the PIM interface. This variable is a read-only field.  |
 Enable  |
 Shows the configured mode of this PIM interface. sparseDense mode is valid only for PIMv1.  |
 Mode  |
 Shows the configured mode of this interface. The valid modes are SSM and sparse. This variable is a read-only field.  |
 DR  |
 Shows the router with the highest IPv6 address on a LAN designated to perform these tasks.  |
 HelloInterval  |
 Specifies how long to wait (in seconds) before the PIM router sends out the next hello message to neighboring switches. The default is 30 seconds.  |
 JoinPruneInterval  |
 Specifies how long to wait (in seconds) before the PIM router sends out the next join or prune message to its upstream neighbors. The default is 60 seconds.  |
 OperState  |
 Indicates the status of PIM on this interface: Up or Down.  |
 Type  |
 Specifies the interface type.  |
