Configure Hosts
Use this procedure to configure the Hosts tab in EDM for DHCP
Server.
- In the navigation pane, select .
- Select the Hosts tab.
- Enter the Subnet IP address and Subnet Mask.
- Enter the host Mac Address.
- In the IP field, enter the IPv4 address that you want to reserve for this host.
- In the Name field, enter the hostname that you want to assign to this host.
- In the TFTP Server IP field, enter the IPv4 address of the TFTP server that you want the host to use.
- In the TFTP Server Name field, enter the server name for the TFTP server that you want the host to use.
- In the TFTP Bootfile Name, enter the file name for the boot image that you want the host to use.
- Select Insert.
Hosts Field Descriptions
Use the data in the following table to configure the Hosts tab for DHCP Server.
| Name | Description |
| Subnet IP | Specifies the network address of the subnet. |
| Subnet Mask | Specifies the subnet mask for the DHCP subnet. |
| Mac Address | Specifies the Mac address of the host. |
| IP | Assigns an IPv4 address to the host. |
| Name | Assigns a hostname to the host. |
| TFTP Server IP | Specifies the IP address of the TFTP server that you want this host to use. |
| TFTP Server Name | Specifies the server name of the TFTP server that you want this host to use. |
| TFTP Bootfile Name | Specifies the file name of the TFTP boot image that you want this host to use. |
