View DvR domain redistribution information on a Controller or a Leaf node.
You can view DvR domain redistribution information only on a DvR Controller.
An error message displays if you attempt to view this information on a DvR Leaf node.
Ensure that you enable DvR globally on the node.
View DvR domain redistribution information on a Controller:
Switch:1#show dvr redistribute
                             DVR Redistribute List - GlobalRouter
SOURCE MET MTYPE      ENABLE RPOLICY
STAT   1   External   TRUE  -
View DvR domain redistribution information for a particular VRF.
Switch:1#show dvr redistribute vrf vrf1
                               DVR Redistribute List - VRF vrf1
STAT   20000 External   TRUE  -
LOC    10000 Internal   TRUE  -
Variable definitions
Use the data in the following table to use the show dvr redistribute command.
 Variable  |
 Definitions  |
 vrf WORD<1-16>  |
 Specifies the VRF name.  |
 vrfids WORD<0-512>  |
 Specifies the VRF ID of the VRF.  |
