Enable DiffServ so that the system provides DiffServ-based QoS on the port. By default, DiffServ is enabled.
Variable definitions
Use the data in the following table to use the enable-diffserv command.
 Variable  |
 Value  |
 enable  |
 Enables DiffServ for the specified port. The default is enabled.  |
 port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
