Configure OVSDB Managed Interface
Use the following procedure to configure a I-SID interface for the OVSDB.
 - Select OSVDB.
 - Select the Interface tab.
 - Select Insert.
 - In Isid, type the I-SID identifier.
 - Select Insert.
Interface field descriptions
Use the data in the following table to use the Interface tab.
 Name  |
 Description  |
 Isid  |
 Specifies an I-SID to use as the managed interface.  |
