Perform the following procedure to configure coordinate based location information of local LLDP-MED on specific ports.
Configuring coordinate based location on port 1/2:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#lldp location-identification coordinate-base altitude 3 floors
The following table defines parameters for the lldp location-identification coordinate command.
 Variable  |
 Value  |
 altitude WORD<1–13>  |
 Specifies the value for altitude. The units of measurement are:
 datum  |
 Specifies the reference datum. The formats are:
 latitude WORD<1-14>  |
 Specifies the latitude in degrees, and its relation to the equator from North or South.  |
 longitude WORD<1-14>  |
 Specifies the longitude in degrees, and its relation to the prime meridian from East or West.  |
