Consider the following when you use the Extreme-Dynamic-Client-Assignments Vendor Specific Attribute (VSA):
Extreme-Dynamic-Client-Assignments takes precedence over FA-VLAN-ISID, EGRESS-VLAN-ID, EGRESS-VLAN-Name, and RAD_ATTR_TUNNEL_PRI_GROUP_ID.
The RADIUS packet is limited to 4096 bytes, but can carry any VSA combination that does not exceed 4096 bytes. The Extreme-Dynamic-Client-Assignments VSA has a variable length and combinations can scale up to 94 VSAs in a packet. To reach 94 VSAs in a packet, each VSA should be about 40 bytes long.
You cannot manually modify dynamic VLANs.
You cannot use this VSA to dynamically create VLANs on a DvR Leaf node.
Static configuration is not supported.
MultiLink Trunk (MLT) and Split MultiLink Trunk (SMLT) ports are not supported.
RADIUS Change-of-Authorization (CoA) and RADIUS Disconnect functions are not supported.
