Use this procedure to modify the assigned name for the Service Identifier (I-SID).
 - Select ISID.
 - Select Global Name.
 - Double-click the name of the I-SID in the ISID Name field, and then type a new name.
 - Select Apply.
Global Name Field Descriptions
Use the data in the following table to use the Global Name tab.
                                 Name  |
                                 Description  |
                                 ISID Id  |
                                 Specifies the index number that uniquely identifies the I-SID.  |
                                 ISID Name  |
                                 Specifies the name of the I-SID, which can be up to 64 characters. This field is not supported on all hardware platforms.  |
| UsedByType |
                                 Specifies the I-SIDs that are in use as services. An I-SID can have one base type or a combination of base types so that multiple services can use the same I-SID at the same time.  |
