Trigger Linktrace (LTM)
Use the following procedure to trigger a linktrace.
The Linktrace Message is often compared to traceroute. An MEP transmits the Linktrace Message packet to a maintenance endpoint with intermediate points responding to indicate the path of the traffic within a domain for the purpose of fault isolation. The packet specifies the target MAC address of an MP, which is the SPBM system ID or the virtual SMLT MAC. MPs on the path to the target address respond with an LTR.
  • You must have a MEP that is associated with a VLAN.
Trigger the linktrace:
linktrace WORD<0–22> WORD<0–22> <1–8191> <0x00:0x00:0x00:0x00:0x00:0x00> [detail] [priority <0–7>] [source-mode <nodal|smltVirtual>] [ttl-value <1–255>]
Switch:1# linktrace md1 4001 13 00:bb:00:00:14:00 priority 7
Please wait for LTM to complete or press any key to abort
Received LTRs:
SeqNum: 10575 MD: md1 MA:4001	MepId: 	13 	Priority: 7
TTL SRC MAC					FWDYES	TERMMEP	RELAY		ACTION
63	00:bb:00:00:10:00	 	true		false		Fdb
62 	00:bb:00:00:14:00  	false		true		Hit
The following table defines parameters for the linktrace command.
Variable
Value
WORD<0–22>
The first parameter, specifies the MD name.
WORD<0–22>
The second parameter, specifies the MA name.
<1–8191>
Specifies the MEP ID.
Specifies the target MAC address to reach the MEP.
detail
Displays linktrace result details.
priority <0–7>
Specifies the priority. The default is 7.
source-mode{nodal | smltVirtual}]|
Specifies the source mode:
  • nodal
  • smltVirtual—Use this value with B-VLANs only.
The default is nodal.
ttl-value <1–255>
Specifies the Time-to-Live value. The default is 64.
