View RSMLT edge support information to verify the RSMLT peer MAC/IP address-pair in its local configuration file and restore the configuration if the peer does not restore it after a simultaneous restart of both RSMLT-peer systems.
 - Select RSMLT.
 - Select the Edge Peers tab.
Edge Peers field descriptions
Use the data in the following table to use the Edge Peers tab fields.
 Name  |
 Description  |
 VlanId  |
 Specifies the VLAN ID of the chosen VLAN.  |
 PeerIpAddress  |
 Specifies the peer IP address.  |
 PeerMacAddress  |
 Specifies the peer MAC address.  |
 PeerVrfId  |
 Identifies the Peer VRF.  |
 PeerVrfName  |
 Specifies the Peer VRF name.  |
