Use the following procedure to configure an aging interval for IPFIX. The aging interval determines how long a traffic flow that is no longer being received, is retained as a flow.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#ip ipfix aging-interval 30
The following table defines parameters for the ip ipfix aging-interval command.
Variable |
Value |
<1-60> |
Specifies, in seconds, the flow record aging interval. The aging interval determines how long a traffic flow that is no longer being received is retained as a flow. The default is 40 seconds. |
