Use statistics to help you monitor Open Shortest Path First (OSPF) performance. You can also use statistics in troubleshooting procedures.
This command provides values for brouter port implementations. For IP protocol-based VLAN interface statistics, use View the OSPF Interface Statistics.
Display extended OSPF information:
Switch:1>enable
Switch:1#show ports statistics ospf extended
Port Stats Ospf Extended
PORT_NUM RXLS_REQS TXLS_REQS RXLS_ACKS TXLS_ACKS
1/3 0 0 0 0
Use the data in the following table to use the show ports statistics ospf extended command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
