View information about the license file for the switch.
 - Click Chassis.
 - Click the License tab.
License field descriptions
Use the data in the following table to use the License tab.
                         Name  |
                         Description  |
                         FileName  |
                         Indicates the file name of the current license. Note:
                    If this field is empty it indicates that there is no license installed on the switch.  |
                         LicenseType  |
                         Indicates the level type of the current license.  |
                         DurationType  |
                         Indicates the duration type of the current license.  |
                         RemainingDays  |
                         Indicates the days left before the factory default trial period expires. Note:
                    For other license types, the field displays 0.  |
                         GenerationTime  |
                         Indicates the date on which the license file was generated. Note:
                    If there is no license installed on the system, this field displays 0000000000000000 H.  |
                         ExpirationTime  |
                         Indicates the date on which the license file expired. Note:
