Modify the ingress mappings to change traffic priorities. As a best practice, use the default mappings.
Do not change the default values. If you change the values, make sure that the values are consistent on all other devices in the network. Inconsistent mapping of table values can result in unpredictable service levels.
 - Click Mapping Tables.
 - Click the Ingress 8021p to QoS tab.
 - Double-click a QosLevel field to change the value.
 - Click Apply.
Ingress 8021p To QoS field descriptions
Use the data in the following table to use the Ingress 8021p to QoS tab.
 Name  |
 Description  |
 InIeee8021P  |
 Specifies the value of the IEEE 802.1p bit of the incoming packet.  |
 QosLevel  |
 Specifies the equivalent egress QoS level (0–7).  |
