Enable ECMP on the switch before configuring the max-path value. For more information, see Enabling IPv6 ECMP.
Use the following procedure to configure the maximum number of ECMP paths.
Enable ECMP on the switch and configure the maximum number of ECMP paths to 4:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ipv6 ecmp enable Switch:1(config)#ipv6 ecmp max-path 4
The following table defines parameters for the ipv6 ecmp max-path command.
 Variable  |
 Value  |
 <1-8>  |
                             Specifies the maximum number of ECMP paths. The default is 1.  |
