View VRF instance status information to determine the operational status of each VRF, as well as other operational parameters.
 - Click VRF.
 - Click the VRF Stats tab.
VRF Stats field descriptions
Use the data in the following table to use the VRF Stats tab.
 Name  |
 Description  |
                                 Id  |
                                 Specifies the ID number of the VRF instance.  |
                                 StatRouteEntries  |
                                 Specifies the total number of routes for this VRF.  |
                                 StatFIBEntries  |
                                 Specifies the total number of Forwarding Information Base (FIB) entries for this VRF.  |
                                 StatUpTime  |
                                 Specifies the time in (in hundredths of a second) since this VRF entry has been operational.  |
                                 OperStatus  |
                                 Shows the operational status of the Virtual Router.  |
                                 RouterAddressType  |
                                 Specifies the router address type of this VRF.  |
                                 RouterAddress  |
                                 Specifies the router address of this VRF, derived from one of the interfaces. If a loopback interface is present, you can use the loopback interface address.  |
                                 DhcpRelayNumRequests  |
                                 Specifies the total number of DHCP requests on this VRF.  |
                                 DhcpRelayNumReplies  |
                                 Specifies the total number of DHCP replies on this VRF.  |
