View operational statistics for the Management Instance.
 - Select Mgmt Instance.
 - Select Mgmt.
 - Select the Interface tab.
 - Select a Management Instance by placing the cursor in a cell within the applicable row.
 - Select Graph.
Interface Counters Field Descriptions
Use the data in the following table to use the Interface Counters tab.
 Name  |
 Description  |
 RxPkts  |
 Counts the packets received on the Segmented Management Instance.  |
 RxError  |
 Counts the packets received with errors on the Segmented Management Instance.  |
 RxDrop  |
 Counts the packets received and dropped on the Segmented Management Instance.  |
 TxPkts  |
 Counts the packets transmitted on the Segmented Management Instance.  |
 TxError  |
 Counts the packets transmitted with errors on the Segmented Management Instance.  |
 TxDrop  |
 Counts the packets dropped before transmission on the Segmented Management Instance.  |
