You must globally enable ICMP Router Discovery.
Change the VRF instance as required. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View.
Configure Router Discovery on a VLAN so that the ICMP Router Discovery feature can run over the VLAN. When enabled, the system sends Router Discovery advertisement packets to the VLAN.
 - Click VLANs.
 - Select the VLAN ID that you want to configure to participate in Router Discovery.
 - Click IP.
 - Click the Router Discovery tab.
 - To enable Router Discovery for the VLAN, select AdvFlag.
 - Configure other parameters as required for proper operation.
 - Click Apply.
Router Discovery field descriptions
Use the data in the following table to use the Router Discovery tab.
 Name  |
 Description  |
 AdvAddress  |
 Specifies the destination IP address used for broadcast or multicast router advertisements sent from the interface. The address is the all-systems multicast address, 224.0.0.1, or the limited-broadcast address, 255.255.255.255. The default value is 255.255.255.255.  |
 AdvFlag  |
 Indicates whether (true) or not (false) the address is advertised on the interface. The default value is true (advertise address).  |
 AdvLifetime  |
 Specifies the time to-live-value (TTL) of router advertisements (in seconds) sent from the interface. The range is MaxAdvInterval to 9000 seconds. The default value is 1800 seconds.  |
 MaxAdvInterval  |
 Specifies the maximum time (in seconds) allowed between sending unsolicited broadcast or multicast router advertisements from the interface. The range is 4 seconds to 1800 seconds. The default value is 600 seconds.  |
 MinAdvInterval  |
 The minimum time (in seconds) allowed between unsolicited broadcast or multicast router advertisements sent from the interface. The range is 3 seconds to MaxAdvInterval. The default value is 450 seconds.  |
 PreferenceLevel  |
 Specifies the preference value (a higher number indicates more preferred) of the address as a default router address, relative to other router addresses on the same subnet. The range is –2147483648 to 2147483647. The default value is 0.  |
