Complete the following tasks to configure DHCP Relay on the switch.
| Steps | Task | Description |
1 |
Configure DHCP forwarding path entries as part of the DHCP Relay global configuration. |
2 |
(Optional). Enable the circuit ID to encode an agent-local identifier of the circuit from which a DHCP client-to-server packet is received. |
3 |
Enable DHCP Relay on a port or VLAN interface. |
